you will need to adjust the limits on your front mech
and if a 44-32-22 chainset, you may want to considerm changing the 32 to something like a 39 and the 22 to a 26 once they wear out.
You can probably take a few links out of your chain to to save some weight, chain slack.
once the 44 is off, put the chain on big-big (the 32 and the granny ring at back) without putting chain through the rear mech, chain should be long enough to go big-big + 2 links, get rid of the rest.
EDIT: as below, you will have an extra “click” on your front shifter, but nothing to worry about, Ive got a 2 x 9 set up with X0 3 speed shifters up front.
