• This topic has 4 replies, 4 voices, and was last updated 8 years ago by jb72.
Viewing 5 posts - 1 through 5 (of 5 total)
  • Converting to 10 speed
  • simmy
    From 9 speed.
    Chain and cassette are worn and I fancy a clutch mech. I’ve already got a 10 speed rear shifter in the spares box.
    Guessing I will need : –
    Chain
    Cassette
    Clutch mech
    Will I get away with using the 9 speed chainrings ?
    Which Shimano rear clutch mech is recommended ?
    How do I know if I’m on a medium or long cage rear mech ?
    Thanks
    cloudnine
    Zee or xt mech.. Pretty sure the chain rings will be fine
    Thrustyjust
    [/quote]Will I get away with using the 9 speed chainrings ?
    9 speed chainrings fine
    Up to you which mech, they are all quite cheap.
    Theory to me is triple = Long, Double = medium , single without extender= short. Extender can use short or medium cages.
    simmy
    Cheers Guys.
    Will the chain length be the same ?
    Thanks
    jb72
    Assuming the largest cog on the cassette is the same – yes.
The topic ‘Converting to 10 speed’ is closed to new replies.
