Viewing 13 posts - 1 through 13 (of 13 total)
  • converting an XTR M970 triple to double
  • turneround
    anyone done this, just need to advise on what bits i need, looking to keep the 9speed xo mech and cassette but would like to change the front as i never use the wee ring and only the biggy occasionally. Id like a nice lightweight bash to replace the outer – can this be done. i run XO twisties so the 3 spd front should be fine on a 2 ring setup
    tomhoward
    I swapped the big ring for a bash, then adjusted the stops on the mech to prvent over shifting onto the new bash.
    That’s it.
    edit
    Go 1×9?
    turneround
    what bash did you go for, i have an E13 on another bike but a wee but over the top for me Flux. did you change the rings?
    Northwind
    Yeah, dead simple- M970 has standard bolt spacing for the outer ring so pretty much any shimano-compatible bashring will fit. It’s only the inside ring which is funky.
    Might need shorter or longer bolts depending on which bashring you use.
    Junkyard
    what they said and I used a Hope bash and also using XTR and XO
    Dead easy nothing special needed as the big ring is standard BCD.
    May need longer bolts if you use a polycarbonate/plastic one
    tomhoward
    It’s the one that comes with the slx crank, took a bit of modification with a dremel, but got there in the end 🙂
    njee20
    I ran TA Chinook 40/28 rings on my M970s, M8x2mm spacers on the inner ring.
    turneround
    ta all 🙂
    turneround
    oh one thing, will i need to change out the rear mech as its currently a long cage XO…thins may start getting expensive!
    Junkyard
    Nope that is what I use as i did not change mine.
    On an orange so not sure how bad ona bike with proper chain stays re slap
    turneround
    dw link on a turner so no proper stays
    zbonty
    Any hot tips for replacement rings? Still running a triple but its gonna get ugly buying replacements.
    scuttler
    I got one of these and wound the derailleur outer-stop back in – http://bbgbashguard.com/
    Keep the rear mech – maybe take some links out. At some point you’ll mash the mech and then you can buy a shorter cage one.
The topic ‘converting an XTR M970 triple to double’ is closed to new replies.
