I’m tempted to buy an old road bike for riding to work and back and generally round town, but to keep things (Relatively) maintenance free I would want to convert it to singlespeed. Whats the cheapest way to do this? And what bits would I need? …even if it means doing some sort of ghetto fixing
How old is the road bike?? I’ve got a Raleigh arena with semi horizontal dropouts, came with an old type screw on freewheel, but the guy I bought it off re dished the wheel and popped a screw on shitmano freewheel and Roberts ya mothers brother
as with everything, the super cheap way is labour intensive, the easy way you might as well buy off the peg, good luck finding a happy medium
frame and forks original (60s/70s) centre pull brakes were long enough drop to cope with changing the wheels down from 27&1/4 to 700, dedicated SS wheelset, one of those BBs that tightens up against itself, cos the shell was very badly cross threaded, quill to ahead adapter, 100mm 6deg mtb stem, flipped……
its a frame of sentimental value, but it would have been cheaper and easier to buy something that fits OTP
I don’t have a bike yet, im looking around ebay/gumtree/ paper etc for things sub £30 basically for something with skinny tyre’s to get around town, basically a fixie with out the skinny jeans and fixed bit 😉
I guess it’ll be a case of find a bike and work from there!
I have an old beater that I wanted to simplify.
It has semi-horizontal drop-outs, so I removed the front and rear mechs and shifters, decided which ratio to keep and shortened the chain accordingly.
Over the next few weeks the chain growth necessitated moving the wheel every 400 miles. With a 7-speed cassette having hyperdrive sprockets, chain retention with low tension is poor. Result is the chain skipped to a larger sprocket momentarily and bent.
Cured the problem with a new chain and a tensioner.
I will substitute the cassette for a singlespeed sprocket when worn.
So the lesson is to fit the tensioner from day one and enjoy the cheaper/simpler ride.
Look at the KMC galvanized chains for approx £7 on CRC.
I messaged the guy with the Falcon (Link in a previous post) asking what frame size it is, but he doesn’t know. However, he did say he was 5ft 5 and could touch the floor. Does this mean, me being 6ft 1, that it would be too small for me? I wouldn’t be able to try it first as it would be my dad collecting it (It’s near where he works) so that’s not an option…
Whooo! Picked one up yesterday (Viscount) for a grand total of £50, slightly over budget, but at least its fully working 🙂 Needs a bit of a clean and im still ummm’ing and ahh’ing over whether or not to single speed it…
The problem with converting many old road frames to single speed is their flexibility.
It’s a great and cheap way to get started, and a good way to keep a well-loved classic on the road.
But once you start building up the appropriate muscles you’ll find the limitations.
I have done lots of this sort of conversion and what you can expect is the frame to flex a lot. Where this gets tiresome is when you’re climbing and the rim starts rubbing on the brakes. You can ditch the rear brake and go fixed, but it generally won’t be long before you’re managing to make the tyre rub on the sides on the chain stays.
(If you live in flatland this may not apply)
Recommendation? Buy a Pompino.
Posted 12 years ago
Viewing 18 posts - 1 through 18 (of 18 total)
The topic ‘Converting an old road bike to singlespeed…’ is closed to new replies.
