Super star components tubeless rim tape and valves, then some proper Stans Sealant fluid is all you need
1) Overlap tape after 2 wraps by 3-4″ (not directly over where the valve hole is)
2) Poke a small hole for the valve
3) Fit a tyre and tube as normal and leave for a few hrs. This helps to press the tape into the rim profile
4) Remove one side of the tyre and the tube
5) Install tubeless valve and a couple of scoops of Stans Sealant, refit tyre bead and inflate to desired pressure
6) If your not using a tubeless ready tyre, spin it round for 10 mins or so covering all the axis to get the sealant properly sloshed about
7) Repeat for other wheel
8) Go ride or crack open a beer
