Viewing 11 posts - 1 through 11 (of 11 total)
  • Convert 150mm Pikes to 160mm?
  • aroche
    Is it possible a all? and if so, is it costly or difficult to do?
    Northwind
    Just needs a new air spring shaft, I think- Loco’ll be able to sort you with the part if so
    plecostomus
    Not possible as far as I’m aware you can space down but not up but with new internals you will be able to.
    gravity-slave
    £35 RRP for a new air shaft, less if you shop around
    darrenspink
    Booyakka
    http://www.amazon.co.uk/gp/aw/d/B00G239WX0?pc_redir=1407723883&robot_redir=1
    Double check its what you need obviously
    aroche
    Sounds good, so stanchions etc are all the same?
    Anyone here have 150mm pikes? Do they have 2 sets of sag measurements? ie. the measurements for 150 and also 160?
    singlespeedstu
    Yep.
    160 51 offset 29er Pikes were unavailable in the UK so i bought 150 51 offsets and put a 160 airspring in them.
    Sorted.
    aroche
    Excellent.
    Thinking of doing a Joe Barnes on one of those Spectrals and turning the fork (Pike 150 comes with it) into a 160 for an enduro weapon.
    (not that I ride anything like JB!)
    SOAP
    Tf said No.
    aroche
    “Tf said No.”
    — As in can’t be done?
    getonyourbike
    I’ve done it to a couple of 150mm 27.5″ Pikes. Works a treat.
The topic ‘Convert 150mm Pikes to 160mm?’ is closed to new replies.
