Looking for some advice here re. a warranty claim on a bike part.
I have had a manufacturer acknowledge that a wheel fault is indeed a warranty issue and that they will replace the wheels without delay as long as I post back the damaged goods. It is only the rear wheel that is faulty however they have said they will replace front as well.
Problem I have discovered is that when the rear wheel failed (2 spokes pulled right through the rim with nipples still attached and destroyed the rim) the wheel instantly went miles out of true and straight into the chainstay and seized up. At the time it happened I was going uphill so came to a stop within a few yards and didn’t notice any damage. However, on closer inspection when cleaning the bike I have found damage to the carbon fibre of the bike frame where the tyre jammed in when the wheel broke. (which I previously thought was grime)
I don’t know if it is superficial or potentially more serious than that. It is approx. 1-2mm deep by approx. 10mm wide and about 15mm long i.e. the area of the tyre that came into contact with it.
I have advised the company of this and await their response.
Just wondering what my rights are here? Can I claim for the damage to my frame? Best case – it is superficial and won’t affect the structural integrity of the bike albeit my resale value will be hit as it looks quite bad and you hear horror stories of miniscule cracks/damage in CF all of a sudden becoming catastrophic failures without warning.
Worst case – it is structural- and the chainstay fails on me and some point in the future.
I would have thought that I would be protected here as a consumer but I am not sure.
P.S. the manufacturer hasn’t had time to respond yet and so far they have been very good when it comes to the wheels alone but i’m a bit worried they come back and say there is nothing they can do about the frame. Where does that leave me?
P.S. won’t name the company here as it wouldn’t be fair until they make their decision
