Boat currently has 4 smallish speakers, can I connect them to a two channel amp?
I presume that instead of getting 30w each the speakers would get 15w
Strangely enough no, if you connect the speakers in parallel you will lower the total resistance (measured in ohm) for example if you connect two 8 ohm speakers in parallel the amp will “see” a load of 4 ohm.
The power rating of an amp is always given with the expected load in ohm. So it would be 30w at 8 ohm with say 0.1%THD (THD = Total harmonic Distortion) at 4 Ohm the same amp may output 60w but the THD will rise as well. essentially you will get the same power delivered to four speakers as you would two, but at the cost of quality of sound.
Some amps can cope with this fine, some cannot. If you are not going to push the volume to much, most modern amps will be fine at 4 ohm. (assuming the speakers are 8 ohm) House hold speakers are usually 8ohm, and car speakers are usually 4 ohm. It will usually say on the back of the speaker.
Edited to add that you can usually halve the rated ohm, on any given amp with no problems, car amps are usually 4 ohm so most will run at 2 ok.
