Need a bit of help.
My house is about 4 feet higher than the roadway, with a raised front garden and a sloping asphalt drive way.
The access to the house is from the driveway, and even allowing for the slope there are still two steps up to the path at the top of the garden which are both about 15″ high, and too high for my dear old mum who is disabled to get up on her own. They are however deep enough (big square paving slab size) that I could halve the height of each by building in new steps on the existing ones to fill in the gap.
The lower one would be onto the asphalt driveway and would be wedge shaped so it’s level at the top but where the driveway slopes. The other would be onto the paving slab.
My plan is to cheat and use postcrete – make an appropriately shaped bit of shuttering to held the dry mix and mix it in situ, making it a bit proud so I can then drop a half width slab on top while it’s still a bit wet so it matches the existing steps. Will it work, do I need to do anything to make it key onto the existing surfaces and will it grab the top paving slab well enough?
