Viewing 26 posts - 1 through 26 (of 26 total)
  • Computer Help Please
  • dickie
    I’m having problems with scripts – keeping getting an error message on here, ‘do I want to run scripts, yes/no?’
    Can’t sort it, tried download new IE, etc but not working – do I need to download JavaScript?
    takisawa2
    Download & install the Firefox browser & do yourself a huge favour.
    bruneep
    wot he said^
    dickie
    I have in ‘programmes’ Mozilla Firefox, is this it & how do I make it run instead of IE?
    breakneckspeed
    Donít download IE8 itís a pile of poo ñ it uses most of your CPU and launch multiple processes that ground you Pc to a halt ñ apparently (according to an article I read) it only functions well on quad core process ñ some kind of MS conspiracy to make us buy new hardware ñ I now use firefox
    devs
    Download the latest java from http://www.java.com/en/download/index.jsp and the latest flash from adobe.com.
    Let us know if that cures it.
    dickie
    devs – done both but no good. When I go to google it says ‘you must have JavaScript enabled to use this page’
    How do I run Firefox?
    Sounds like you have not given IE permission to run script for this site.
    dickie
    OK so how do I do that?
    stratobiker
    If you’ve got Firefox on your machine just launch it.
    Assuming you’re connected to the web it should work.
    To be honest I’d just use firefox like others have said, it’s not hard just launch it like you do any other programme.
    dickie
    I think the problem is BTYahoo! is set as default browser?
    stratobiker
    Can you launch Firefox?
    dickie
    Yes.
    I’ve jst gone to the BTYahoo home page to update the browser so I’ll see if that helps.
    bruneep
    update which browser?
    are you using FF or IE?
    dickie
    How do I choose which browser BTYahoo uses?
    bruneep
    open FF go to tools>options>advanced>system defaults and tick the default browser.
    you can also set your home page in tools>options>main and set your home page to whatever you want
    dickie
    In >advanced – only can ‘reset’ or ‘restore advanced settings’.
    Disable Script Debugging (Internet Explorer) is ticked – should it be?
    Disable Script Debugging (Other) is ticked – should it be?
    bruneep
    dickie – Member
    In IE mine are both ticked, but I never use IE. Give FF a go 😉
    dickie
    I would if I could only get FF to be the default browser – Should I unistall internet explorer than its got no option?
    Make sure it’s FF 3 you have installed.
    Tools->options->Advanced-> select general tab the bottom tick the always check box.
    dickie
    I have two options;
    Tools>Internet Options>Advanced – no always check!
    or
    Tools>Browser Options>General>Always check to see if BTYahoo is the default browser.
    FFS Man! Run FF and follow the the bit above.
    bruneep
    sorted yet 🙄
    Someone probably told him to turn his PC back on and off again but he’s not sure how to put it back on and can’t ask on here. 😆
    dickie
    Hey nice one Drac – the neighbour turned it back on for me!
    Seem’s Ok at the moment.
    Thanks everyone.
The topic ‘Computer Help Please’ is closed to new replies.
