“fsr frames and the front mech cable pinch bolt
Swing arm gets in the way.
Even Spesh changed the bolt to a hex head “
From the setting up the front mech perspective it wold seem a bit rubbish. Ii guess theyve decided saving a little bit of weight in using a straight, not dropped nds chain stay was worth the extra hassle
When I built my spesh frame up I couldn’t worjk out what that bolt was for, until I came to setup the front mech
“‘tool free pad replacement’ on Juicy’s.”
Get rid of the clip thing on the back of the caliper, unless you get the knbobbly bit on the pistons to fall off, you don’t need the clip. It makes it easy to swap pads
The clip looks like an after thought anyway
“shimano pedals just go on and on and on”
The bearings might, but ime the bodies don’t and while new cleats aren’t as bad, my worn m540 and m520s I can pull up/out of far too easily
cant believe nobody has mentioned superstar yet
A crank brothers multitool half the tools/bits on it were rounded within 6months. The other half I had rarely used
erm, Kenda tyre standard wire or folding sidewalls. The sidewall breaks (3 tyres) before I’d rounded the squares of the knobbles. At least on the rear. Front’s just looked very worn around the bead. Before being assigned to a certain death on the rear
