I wouldn’t bother with the Ohlins unless you are going with the RXF 36 coil, they really aren’t as sensitive as Lyriks or 36s – no matter how much you play around with the twin positive air chambers.
The 2018 36 is awesome even without the PUSH ACS-3 coil, anyone who tells you they are overdamped even when fully open is talking a massive load of steaming bollocks.
They have masses of chassis stability topped with great sensitivity, when you run the rebound fast they don’t feel bouncey in the deep stroke and stay high up in the travel in the sweet zone over braking bumps.
Best **** fork I’ve ever owned, I’m in agreement with MBR when they did the Lyrik vs 36 test – in that the RS forks bang through their travel quickly and whilst they feel plusher on individual or initial hits, they stiffen more during repeated square edged hits or braking bumps.
You should run them as an intermediate rider as well, if given the choice. You may be able to get the Lyriks feeling more open on the first few hits by running them wide open, but the chassis stability of the 36 simply adds more safety. Instead – get fitter and stronger.
I wouldn’t recommend spending 1400 quid on a fork, but my ACS-3 36’s have a LOT less stiction than my old mans air Lyriks – unless you want to get the most out of a set of 36s that you already own…then go for the coil upgrade. Thus I’d wager an MRP Coil Ribbon would be a good shout, if you want coil but don’t want the expense of a two stage spring (the MRP uses the ramp up of the natural pressure build up found in the stanchions, which isn’t much…doesn’t it – it doesn’t have a seperate closed air spring like the PUSH mod) and the 36 chassis and damper.
