D0NK – Member
…fancy telling us more?
Off the top of my head problems could include, acting like a sail in the wind, moving from drops to hoods and back, standing to seated and back, signalling, cape catching on things (bars, levers etc). But like I said no experience.
First of all a cape is not the perfect solution, but possibly the least imperfect one for road use.
It is cheap, versatile, and much faster to deploy than waterproofs.
A cape can catch the wind, but usually when it’s lashing down it’s not that windy. If the wind is cold, I’ll often wear the cape even if it’s not wet because it’s better than most “windproof” clothing.
Any decent cape will have thumb loops which will stop it blowing up. With the thumb loops it moves with your hands, thus signalling, changing hand positions are possible. I sit on the rear of the cape so that doesn’t blow around.
The cape I use also has a couple of armholes which makes it possible to use it like a poncho off the bike.
When the wind is so strong that the rain comes at you horizontally it’s wiser to seek shelter than ride, but waterproof breathable jackets still get water running down your neck or up your arms plus whatever is happening with your legs. But a cape can be the shelter – this where a hooded cape excels.
If you hunker down when stopped your cape is like a mini tent, and with the hood pull strings tightened, the only thing that’s getting wet is your face (if you’re daft enough to face the weather). The rest of your body gets nice and warm in the cocoon.
The best capes I have used were the old oilskin ones because the weight made them lie better. (I think Brooks may still supply them.) I currently use an inexpensive Raleigh branded cape which is lightweight nylon but folds quite compactly, so that’s an acceptable compromise but not quite as good as the real thing.
Maybe the best thing about a cape* is you can ride in normal clothing so you can dress for where you’re going rather than the road.
But it must be added that a cape without good mudguards is useless.
*Edit: actually the best thing is the cost! I think mine cost £12 several years ago whereas a decent weather proof jacket will cost much more.
