Email/message me for more info.
Domestic meters are usually U6 = 6 cubic meters = 65kW, so depends on the appliance rating and the total amount that could be demanded at any one time for all your gas appliances (boilers, gas fire etc).
The service pipe can potentially support more than this, depending on the pipe size and distance from the gas main. Speak to your supplier and ask for a GT1 check, that should give you an exact figure of what your service pipe is capable of. If it’s within what you need, it should just be a case of them fitting a larger meter.
If not, the service pipe might need to be upgraded, this would be done by whoever owns the gas network in your part of the country – whereabouts are you? Depending on your requirements this may well be done FOC if the meter position isn’t moving.
If this is for commercial use though, then an external isolation valve needs to be fitted outside whatever the case.
As I said, message me for more info, this is my day job.
