I know quite a few people that would charge £250 for fitting. It wouldn’t include anything other than taking the old one out and putting a new one in. Once you start adding things like magnaclean, RF stats and stuff it takes longer so costs more. The only way it would be £1800 is if they were fitting something like WB 42CDi or Vaillant 937 which they won’t be cos it’s only a 3 bed semi.
If their engineer put a boiler in then told them it’ll only last 10yr and comes back exactly 10yrs later and tells them they need a new one then I’d be looking elsewhere. Unless the old one has packed in catastrophically then it would still be cheaper to get it fixed (depending on the make).
TR – £2100? Oil fired Combi?
Quick edit – Magnaclean not required for warranty it is good to have. Most manufacturers just insist that inhibitor has been used as when they come to check they will sample it and if it’s not in there warranty is void. Most of the time they just try to get out of it by blaming it on an installation error anyway.
