To give an idea of Weight, Lemond Platinum OX frame, carbon forks, Open Pros on Centaur 32hole DB spokes, Vredestein Fortezza tyres, Chorus, Centaur, Veloce mix groupset (mainly Veloce) old dual pivot Veloce brakes, , Bontrager Bars and Setpost, Pro stem, Fizik Pave saddle, Time pedals, bottle cages, computer, No attempt to save weight has been made. Apart from the Fork there is no carbon.
it is a 57cm and total weight is 20lbs. It will never be as light as a top end carbon or alu frame, but for a do anything without worrying about it getting a few knocks i don’t think you can go wrong. If i want i can save a couple of pounds, a few carbon bits, a set of Mon chasserals, etc
Where it wins, is it is comfortable and it has a certain classic look to it. If i hadn’t of got it as a warranty replacement i would have had a look at a Master, Pegoretti, Gios, Bianchi, they all did/do nice classic looking steel frames. The alternative would be Rouke or Argos, etc and get something made. Problem would then be i would have had to think about the paint job!
