I’ve noticed the same thing – you can certainly see where the grease on the spring has changed consistency and taken on the slight pinkness of the SRAM suspension oil.
To combat this (i.e. make sure there is enough lubrication on the bushes to prevent wear), I make sure the bushes/seals have grease put on them and have slightly increased the amount of oil I put into the lowers. With my 2012 Lyriks it was meant to 10ml of 15wt, so now I put in 15ml of 15wt and normally a couple of ml of heavier weight SRAM red rum fluid.
Whether this is going to help prevent wear or not, I don’t know, but it is no more effort really.
Perhaps other people have some different ideas.
