By the time you’ve paid postage both ways you might as well get one from eBay:
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F161207194396
Handy to have lurking as a periodic check (annual service and boiler strip) is handy to know everything is still good.
You’ll need to take off the double spout from the Portafilter and use a load of ptfe tape but it works well.
Small tip: it’s not an oil dampened gauge. On each test, take off the Portafilter, empty out the water and put it back on. The extra air volume dampens the pump pulsing and keeps the gauge needle steady. When you hit the button to stop the pump, the air blows out through the 3 way solenoid and the Portafilter fills with water, then when you hit the brew button again the needle bounces all over if you didn’t take the Portafilter off.
