Just got back from a day out to CYB today…. 😀
Beast, as above, can be shortened by cutting off the top fireroad loop. This time I went a little way up the fireroad as signposted from the road just past the cafe, then picked up another fireroad heading back the other way – this emerges at the bottom of the fireroad which leads up to the start of the Addams Family descents. The alternative road climb is piggishly steep.
You could miss out the final fireroad slog up to Beginning of the End by taking the blue back to the centre, having lunch, then instead of starting on Tawr Du, head up to the upper-park and pick up ‘Glide’ from Beast – the short bit that goes under the bridge, then follow Seven Sisters down to where it crosses Tawr Du, and so on from there.
I actually did the first two sections of Minotaur as a fun preference to ‘Badger’ and ‘Pinderosa’, the first of which seems to be just bumpy for bumpy’s sake.
And I fell in the stream crossing on Pink Heifer. Don’t do that. 😀
