Always used http://www.co2cartridges.co.uk (same site as tyre inflators, just rebranded).
ali69er – Member
Tyre inflators is a bit steep for postage. Not sure it really works out on balance
£4.99 on a box of 30 that costs £17.99, total £22.98. vs £26 at Wiggle. Though nice to see a big name retailer now doing big boxes and more reasonable prices.
pnik – Member
or can you do something else with them?
Seat tubeless tyres dead easy.
Though I’ve finally got the knack with a track pump and massive amount of soap suds, that I usually can do it without CO2, but occasionally I give up and use the cart.
I also use mine to fix other people’s punctures (while advising them to go tubeless). Occasionally had a puncture that’s taken the pressure down before sealing so re-inflate with one, and less frequently had to put a tube in so used them then.
Box of 30 will last me a long time, but I’ve used them all up over a couple of years, and they work out massively cheaper than LBS prices or online prices for just a few (which are in the £1+ per cartridge range. Though seen fancy branded ones in an LBS for over £10 a cart!).
