All prices are with postage and will be posted at the weekends, I am open to sensible offers. My email is in my profile please use that to contact me as I cant check the forum that often.
Bicycle tyres:
Second from left:
2x Maxxis Minion rear super tacky, 26x2.5”
40% left
£5
2 of the right
2x Maxxis High Rollers, UST tubeless, super tacky 26x2.7” , silkworm
Used very little. 95% front and 80% rear left.
£40 pair
Crank Bro Malett, 2005, but I bought them new in 2007 and had 2 seasons use. They have been sat in a box since. Very used and the paint has worn off but spin freely and the clip in mechanism works perfectly.
£15
Old style flat metal pedals
£2
2 sets Hope organic brake pads for Mono 6. New still in packaging
£5 each set
1 set that are lightly used. Free if you buy the lot.
FSA FR270 seatpost – 31.6 diameter 420mm long. Light use but has a few marks on it.
£17
Promax seatpost. 27.2 diameter, 300mm long. Used and has scratches to the paint but is not damaged. Black post with silver head
£7
ITM Road Racing stem (black), used but in good condition. 105mm standard clamp
£7
Stem – About 90mm. Unbranded silver, standard bar diameter.
£5
Magura Julie 2004 – Rear 160mm wavey disc, 6 bolt. Pads changed and only used a couple times.
£25
Hayes HFX 9 DH front brake –8”, 6 bolt rotor. Its got a few cosmetic scratches but isn’t damaged in any way. Works perfectly. Pads are new. Comes with IS front mount.
£40
Disc mounts, both are new– £6 Avid rear 74mm post mount for 160mm rotors ( num 32)
-£6 Rear 74mm post mount for 8” rotors. (74-30)
All the following LX M570 kit was only used on my commuter so they have only ever had gentle use.
LX V-brakes Front & Rear– These are the double cantilever ones that are excellent. In very good condition. Some pad left but they will need changing soon. Includes noodle and outers.
£15
LX Front mech – 31.8mm. Top pull bottom swing. A bit of use but in good condition.
£5
LX Brake levers & shifters – 9speed, front and rear. All works perfectly. In very good condition.
£15
Foxshox spring 500x2.80
£10
Hiplock bike lock. Brand new in box and never used.
bicycle lock developed specifically to be worn on the body while you are riding and then lock your bike up with it when you stop . http://www.Hiplock.com for more info.
The chain part is black with reflective writing and the lock is green
£50
Thule rapid foot system adaptors that are no longer needed
Fits:
Ford Escort,4dr sedan 91-99, 5dr hatchback 91-99
Ford Orion, 4dr sedan 91-99
Ford Scorpio, 4dr sedan 90-94, 5dr hatch 86-94, 4dr sedan 95-98
Peugeot 406, 4dr sedan 96-
£5
Thule 502 Load stops for roof racks. The box is quite tattered but the stops are brand new and haven’t been used.
£15
