Bontrager Rhythm Pro tubeless ready wheels. Great lightweight all-mountain wheels with scandium rims. 28 spokes. More info at http://www.bontrager.com/model/07855
Need tubeless rim strip and valve to run tubeless: strips are less than £3: http://www.cyclesuk.com/361-555563
Cheapest found £450 for wheelset.
Brand new unused pair £235
Shimano SLX 'honeycomb' bashguard for 36T. Used with some scuffs. £13
SDG I beam micro (new style) seatpost 27.2mm 400mm . Used. Some minor wear to anodising £22
XTR front mech 34.9 bottom pull , low-mount NOT conventional. Pivoting ‘parallelogram’ action at bottom of cage. Used with wear to ‘coating’ where chain runs, works perfect no play at all. £25
Shimano LX cassette 9spd m580 11-34. Brand new unused. £25
SRAM PG970 11-32 cassette. Brand new – unused. £30
Titanium shock spring. Progressive make: fits 5th Element and Fox DHX. 2.25” stroke x 400lbs, 130mm long. Only 175g. £80
Hope saint 10mm thru axle & Shimano Saint rear mech and 10mm Hope Pro2 rear axle conversion. Few scratches to mech but works perfect: spring string and had new jockey wheels recently. Will work on any QR frame for bolt-thru stiffness and super-tough mech (needs 135mm spacing and Hope Pro2 rear hub). £40
In Sheffield
davewoods33(AT)hotmail.com
