I’ve changed a couple of bikes recently and have a load of spare stuff lying around. Prices include postage. I’m live in Sheffield and work in Hailfax, Castleford and York. I’m happy to do collections. If you have any questions just drop me a line.
Hardcastlesteve(at)hotmail(dot)com
Photos of everything are here:
http://s927.photobucket.com/albums/ad112/hardcastlesteve/Parts%20for%20sale/
DRIVETRAIN
SRAM Attack shifters – 9 speed for Shimano mechs. Still in box, never used with inner cables present. £40
E13 SRS Chainguide – Black, ISGC 05 mounts, with bashguard and bolts. Marks to bashguard from impacts but all works fine. Up to 40 tooth chainring. £25
WHEELS
DT Swiss E440 rims x 2 in black with specialized branding. Built in to wheels on a stock bike but never ridden the stripped down and replaced. Nice and light. Mint condition 32 hole. £40 posted for the pair
CONTACT POINTS
Specialized seatpost – 30.9 x 310mm, black but silver lower down from raising and lowering. £12
System X seatpost 30.9 x 250mm long. £10
Race Face evolve stem 110mm x 6 degree. Standard 25.4 bar size and 1 1/8th steerer. Black, good condition. £12
Plastic saddle – Lightweight (approx 200g) plastic saddle with standard rails, ideal for lightweight 4x/dj builds. £10
SDG I beam seatpost 31.6 x 290mm (cut down). Some minor marks but very good condition. £15
BRAKE STUFF
Shimano 160mm rotor. Used but still with plenty of life left £7
180mm Rotor, 6 bolt, not sure of brand, never been used or fitted. £10
Brake mounts 203 is to post rear £4 each shimano x 1 avid x 2
Shimano front is to post 203, new £4
SUSPENSION
Rock Shox Lyirk R fork – Taken from a 2010 Specialized endure. Tapered steerer (195mm long). 160mm travel, air spring, adjustable rebound, maxle lite. £250
Fox 36 RC2 Vanilla fork – 2010 QR lower equipped 36 fork with the best rc2 cartridge. The lowers say float not vanilla but I converted to spring as I prefer the performance. There is no wear on the stanchions from the bushes but there is a mark on one from a rock, the photo makes it look worse than it is due to the flash. Also have some cable rub on the crown but nothing serious. £300
Fox 36 Vanilla R damping cartridge – Complete cartridge, works fine, rebound adjust works. £40
Fox 36 axle screw type, good condition. £10
Fox 40 axle screw type, good condition. £10
Fox 40 lowers, grey scratched, seals are 2 months old bushings still tight. £70
Fox 40 top crown – Flat, black no direct stem mount bolt holes. £25
OTHER
Sony PSP – White PSP with charger, box (I think), original carry case, headphones and 8 top games. Very good condition. Bought when I was travelling a lot with work to fill time in airports. £80
