I’ve changed a couple of bikes recently and have a load of spare stuff lying around. Prices include postage. I’m live in Sheffield and work in Hailfax, Castleford and York, I’ll also be in Bristol over the next month as well. I’m happy to do collections. If you have any questions just drop me a line.
Hardcastlesteve(at)hotmail(dot)com
Photos of everything are here:
http://s927.photobucket.com/albums/ad112/hardcastlesteve/Parts%20for%20sale/
DRIVETRAIN
SRAM X0 Rear mech – upgraded metal jockey wheels, 9 speed, good condition and no play. £50
SRAM Attack shifters – 9 speed for Shimano mechs. Still in box, never used with inner cables present. £40
E13 LG1 Chain guide – ISCG05 Fixing, up to 40 tooth chainring. Honestly used for 1 weeks holiday on my trail bike so very good condition. £45
E13 SRS Chainguide – Black, ISGC 05 mounts, with bashguard and bolts. Marks to bashguard from impacts but all works fine. Up to 40 tooth chainring. £25
WHEELS
Red Hope Pro2 Evo hubs on Black Mavic X317 Rims with black spokes. 32 hole, 6 bolt hubs in 20mm front and QR rear. Fitted with 26 x 2.35 Bontrager XR4 tyres and tubes. £210
DT Swiss E440 rims x 2 in black with specialized branding. Built in to wheels on a stock bike but never ridden the stripped down and replaced. Nice and light. Mint condition 32 hole. £40 posted for the pair
CONTACT POINTS
Sunline V1 Bars with grips – Cut down red V1 bars (720mm wide) with Sunline big s grips in black. Very good condition and a great shape. £35
Specialized seatpost – 30.9 x 310mm, black but silver lower down from raising and lowering. £12
Race Face seatpost 27.2 x 350mm long. Black with silver head. Some marks from raising and lowering. £12
System X seatpost 30.9 x 250mm long. £10
Race Face evolve stem 110mm x 6 degree. Standard 25.4 bar size and 1 1/8th steerer. Black, good condition. £12
Plastic saddle – Lightweight (approx 200g) plastic saddle with standard rails, ideal for lightweight 4x/dj builds. £10
SDG I beam seatpost 31.6 x 290mm (cut down). Some minor marks but very good condition. £15
BRAKE STUFF
Hope Tech M4 Brakeset and X0 Shifters on matchmaker clamps – These came on a bike I bought recently but I run Shimano on all my bikes so these are for sale. Very good condition and little use. All silver with black caps. Shifters are Sram X0 for 3 x 9 gearing. Saw tooth rotors are included 203 Post mount front and 185mm IS rear. Braided Hose lengths F 850mm R 1580mm. £250
Shimano 160mm rotor. Used but still with plenty of life left £7
180mm Rotor, 6 bolt, not sure of brand, never been used or fitted. £10
Brake mounts 203 is to post rear £4 each shimano x 1 avid x 2
Shimano front is to post 203, new £4
SUSPENSION
Rock Shox Lyirk R fork – Taken from a 2010 Specialized endure. Tapered steerer (195mm long). 160mm travel, air spring, adjustable rebound, maxle lite. £250
Fox 36 RC2 damping cartridge and bits – the stanchions on my 36’s died so the rest of the fork is available. Cartridge was serviced 1 month before the forks went so everything works perfectly. £80
Fox 36 axle screw type, good condition. £10
Fox 40 axle screw type, good condition. £10
Fox 40 lowers, grey scratched, seals are 2 months old bushings still tight. £70
Fox 40 top crown – Flat, black no direct stem mount bolt holes. £25
