Getting rid of spares, bits off new bikes & Clearing Out the loft
Bit of everything on offer! Prices exclude postage unless stated.
Photos: http://www.flickr.com/photos/flipd1/ and go to bike bits for sale.
Any questions just ask. Pay by Paypal.
Wheels
Brand New, UNUSED wheelset off new bike. Rims: Alex Rims SX44 32hole. Hubs: DT Swiss 350. Spokes: DT Swiss. Front wheel hub is compatable with 9mm, 15mm & 20mm axles, comes with spacers for 15mm axle. Rear wheel hub is 142mm width. Rear hub alone retails at £150!
Front wheel - £90
Rear Wheel - £110
Also available are Schwalbe Nobbly Nic Triple Compound, Evo, Tubeless Ready tyres & tubes, Tyres never been ridden on. £15ea
Mavic Cross Ride Disc wheelset. Wheels off my girlfriends new Lapiere, seen very little use so in VGC, front wheel immaculate, rear wheel as odd scratch & small ding. QR hubs. Very nice looking with straight pull, flat profilled spokes. Can sell as pair or individually.WEIGHT; Front 885 g, Rear 1035 g. £80
WTB laserdisc Dual Duty AM/Freeride Wheelset 2009, 26", 20mm bolt thru Front, QR Rear, 135mm width, scratches on rims from use, been touched up, bearings replaced last October & wheels not used since, running true & smooooth. These are an expensive, light, strong wheelset. Front weight 1000g, rear 1050g - £40each + P&P
DMR Revolver Hub, for front wheel, 32hole, black, used but in good condition, takes sealed cartridge bearings. fits 20mm axle.
Comes in original packaging with DMR sticker. Reatil is £45 new. £15
Spares or Repair REAR WHEELS:
An Alex DM24 Rim (26inch) on 32 hole shimano M475 Hub. The hub has got no bearings & 1 spoke missing. the rim is in good condition with a few small scratches. Can come with Shimano cassette & 160mm rotor as pictured or sold seperately. £15
Sun Ringle S-type rim on 32 hole Shimano M475 hub, disc compatable. Hub & spokes in good condition, rim has small crack £15
Drivetrain
Shimano Saint Cranks & BB, 68/73mm width. Spacers included. 165mm length, Single ring & double & bash compatable. Rub on left crank arm, bearings run smooth, only cosmetic damage to cranks. £80
Sram X9 Chain rings 44t, 33t, 22t from 3x10 speed set up. Can be used with 8&9 speed set-ups. Taken off new bike. 44t outer ring never been used, 33t & 22t chain rings used for 1 week so very slight wear & signs of use. £10 each
BRAND NEW Blackspire 22T 'Chuck Ring' Chain ring, 8/9 speed, 5 bolt. £8 posted,
BRAND NEW Shimano SG-X 22 tooth, 4 bolt, black chain ring. £9 posted
Used 38tooth, 4 bolt, black chain ring - £4
Little Used Race Face X TYPE 22T chain ring v. little wear - £5
Blackspire C4 Bash Guard - Clear Polycarbonate Bash Guard, upto 38T, 5 bolt, BRAND NEW! £10
Crank Bolts in perfect condition for Isis Bottom Brackets both M12 & M15 available which fits all types of Isis BB. £2
Chain guide roller with cog for use with numerous Guides that add tension at front chain ring.Complete with bolt & spacers. Used but in good condition, fully working order. £5
Deraileurs & Shifters
New 2011, unused Sram X9 10speed Rear mech, white, medium cage. Taken off new bike straight away mech is as new. £50 posted, retail is £100.
2011 Direct mount Shimano XT M770 Dual Pull Front derailer 3 speed used for a week so in VGC. 9 & 10speed compatable. £15
2011 Sram X9 3 speed shifter for front derailuer with inner & outer cables, matchmaker compatable. Was used with 3x10spd but would work with 2x10 & 9speed groupsets. Used for 1 week with above front mech, in VGC. £20
Shimano Deore 2speed front mech taken off bike, in perfect condition. £10
X9 Front Shifter w/ inner & Outer Cables; missing top cap but working. Matchmaker compatable. £8
Spares or repair; broken deraileur's:
1 Shimano LX 9 speed, medium cage, pulley part of body broken off, everything else in VGC £5 posted
1 Shimano Deore 9 speed, long cage, missing outer half of cage & jockey wheels. Everything else real tight and true. £5 posted
Frame & Forks
2005 Kona scrap iv had since new, original decals, some scratches from use but the frame is bullet proof. comes with head set, Kona seat clamp, BETD derailuer hanger, chain device, Kona seat & seat post. Real solid frame that I had as a real do it all bike. Disc brake tabs, 68mm BB shell. £60
2009 Rock Shox Pike 426 Coil fork. Super solid fork with 90-140mm travel via u-turn. Left stanchion has got patch where anodising has rubbed through sometime ago. when i noticed this i replaced oil & seals & hasn't got any worse. They do still feel an amazing fork. £150
Fox 36 Upper steerer assembley is one piece press fitted unit including upper stanchions, crown & steerer tube with star nut fitted 190mm steerer length. compatable with all Fox 36: Van, R, Float, RC2. No internals. There is small scratch high up on one of the stanchions shown in the photo. £35
Brakes
Brand New Shimano Deore LX V-Brakes; Full kit, Front & Rear Brakes, Front & Rear Levers & 2 Inner Cables. Retail £90. I bought these to put on my commuter mtb bike, but bike got nicked before I put them on! Still in original packaging. £35
New pair of Hayes 9 brake pads, Organic compound - £6
New pair of V-brake blocks, thread type, monoblock, 73mm. - £1
Controls
Brand New Lapiere Handle bar - Handle bars taken off newly bought Lapiere Zesty, not used. does have scratch from delivery on under side, grips should cover. Lapiere XC Riser bar, 680mm width, 30mm rise. £15
Lapiere Stem 80mm Off new Lapiere, unused, in Brand New Condition. Fits 11/8 steerer & 31.8 mm oversized bars. light weight & extremely strong with nice 2-piece bar lock. £20
Lapierre Stem clamp & bolt, unused, small scratch from delivery, black, 11/8”- £3
Giant Stem clamp & bolt, black, 11/8”- £3
Cane Creek External headset bearings, 11/8”, top cap cover & compatible steerer crown race for forks - £5
Other
Giant QR Seat Clamp, black, used in good condition - £5 posted
New Replacement Clear Lexan Lenses, Anti fog & Anti scratch, w, tear off tabs for FOX Main & Main Pro Goggles. Still in packaging - £4
New Yale Wall/ Floor Anchor. Mount to lock bikes to inside or out or in vehicle. New, in original packaging, never used. £5
Bikes
I have an old Retro Mustang BMX in mint condition, it was an 'orniment' for several years but for the last couple its been in my parents garage. Its silver, with original padding, front brake, braking rear hub, mud guards, rack. Beautiful bike! £60 bargain!
Giant Boulder Alu Lite Fully Rigid Mountain/Commuter Bike. Had the bike since new just used for the 1mile commute to work & kept in doors so in very good condition, few scratches.
21 speed grip shift, v-brakes with new blocks, full mud guards, carrier rack, toe grips, shimano group set, new tyres.
Bike will not come with Brookes saddle. £100 pick up only unless postage paid.
1999 Specialised FSR Comp in great condition. My girlfriends beloved FSR, she has had this bike from new, bought in New Zealand & brought it with her when she came to the UK, now its time to return to the South & cant find space to take it so I'm looking for a good home for him.
She's mainly used this bike for commuting the couple of miles to work so kept it running nice all these years.
The frame is a medium, in good condition, some scratches & cable rub. Most components are original, the wheels, tyres, grips, chainrings & cassette have been replaced through its life. Everything is working fine but there is some slight play in the lower rear shock bushing, but apparently this can be replaced easily!
Kit includes:
Rock Shox Judy C Forks, 3.15" travel
Rock Shox Deluxe Rear Shock, 4.3" travel
Dia-Compe 735 Direct Pull brakes, Avid SD-1.0 L levers
Shimano Deore LX RapidFire SL Shifters
Shimano Deore LX Front Mech
XTR rear mech
Specialised bars, stem, headset, seat, post, BB & crankset - Specialized ForeArm Comp, 22/32/42 teeth.
Non original:
9spd shimano cassette
Shimano deore front wheel
Quando rear hub on x-plorer Rim
Kenda tyres
SPD pedals
Photos:
http://www.iimmgg.com/gallery/gfdec832a0b1d75c1cde1d98c4f5724f3/
The frame is blue, red & white with red forks.
