Are the brakes especially stiff? Going by the mention of the brake pedal, it could be that the vacuum pump is iffy, which feeds both the brake servo and the vacuum solenoids which would also then affect the turbo actuator…
I hope it’s not anything more serious, as the head gasket went on mine, resulting in it revving out, unable to be switched off by the key as it burnt the oil… bloody thing got me in trouble with the law too; that said, it’s unlikey it would start due to low compression if the head gasket has gone, so probably not worth worrying about yet.
