Got a Mk 10 joystick which has a 2900mAh battery in it, run time is 1.5 hours on full
I want to run an additional battery to supply it, but am after a cheaper alternative than the Exposure support cell (£40)
So if it drains a 2900 battery in 1.5 hours, do i need a powerbank type battery that can supply at least 2A?
Tried with an Anker Lipstick but this will only charge it, not supply power when the light is on, but just checked and the Anker is only rated at 1A so i’m assuming it cuts the power to the light as the current draw is too much.
Amazon has some 2-2.4A USB power banks so am looking at those. eg
https://www.amazon.co.uk/Portable-RAVPower-External-Technology-Smartphones/dp/B00X9VKZIO/ref=sr_1_7?ie=UTF8&qid=1474533706&sr=8-7&keywords=2A+lipstick+power+bank
EDIT actually the specs on that are confusing as lower down it says only 1A.
This one may work
https://www.amazon.co.uk/RAVPower-Portable-Charger-External-Technology/dp/B00Y2RFNI6/ref=sr_1_4?ie=UTF8&qid=1474533005&sr=8-4&keywords=2a+power+bank.
Its amazon though so i can easily return it if doesnt work!
