• This topic has 8 replies, 6 voices, and was last updated 8 years ago by tang.
Viewing 9 posts - 1 through 9 (of 9 total)
  • Cheapest and Easiest Way Upgrade to 1×10 Cyclocross
  • Jase
    My daughter has an Islabike Luath and doesn’t like the thumb shifter on the Sora leavers.
    Thought I would change them to 105 shifters and at the same time change the current double setup to 1×10. As it’s a £500 bike wanted to do it as cheap as possible.
    Was originally thinking of getting a 10s chain and cassette (£30) plus a narrow/wide chainring (£25). Total £55
    However, the cranks are 5 bolt 110bcd and can’t find a narrow/wide chainring in 32/34 teeth for 110bcd.
    So looks like the options are either:
    1. 10s chain, cassette (£30) and chainring (£12) with some kind of chain guide (£50). Total £92
    2. 10s chain, cassette (£30), new 160mm crank arms (£50) and narrow/wide chainring (£25). Total £105
    Once I factor in the cost of the shifters both options are more than I really want to pay so anyone one else done something similar in a cheaper way?
    Thanks for any help.
    Chain guide could be under £50 maybe:
    nGEAR jumpstop (£10) + outer bash about $25 delivered:
    http://bbgbashguard.com/products/110-bcd-34t-black
    http://bbgbashguard.com/products/110bcd-32t-black
    Edt this should negate the need for a NW ring, or a NW ring should avoid the need for a chainguide. Guess it depends on how hard it is being ridden.
    Will the rear mech work ok with the 10 speed shifters btw?
    Also, will the cassette have sufficient range with a stock offering?
    padkinson
    No-one likes the little thumb shifters on the old Sora. That’s why they changed it to a proper dual control shifter like 105 & upwards.
    So you could go 1×9 pretty easily with a change of crankset and a n/w chainring?
    breatheeasy
    You won’t get a 110bcd 32t chainring – won’t go small enough. TA used to make a 33t version but thats not wide/narrow.
    Spa Cycles do a Stronglight chainguard for a tenner, plus a couple of quid for a Dogfang to keep the inside sorted too if a Jumpstop is too rich for you.
    Do some checking on the rear mech compatibility – not sure if you might need to factor a rear mech as well…
    Jase
    I had been looking at the Paul chain guide but the above seems a cheaper way so will have a look into it.
    Mech is Ultegra so hopefully will work ok.
    Thanks for comments.
    bensales
    Rather than a chain guide, how about leaving the current front mech on, and using the H/L screws to fix it in place as a guide?
    Jase
    Yeah thought about that but wanted something that looked a bit nicer.
    Jase
    In the end I ditched the idea of 105 shifters due to cost.
    Went for Claris 8 speed shifters, sold the current shifters for more. Got the bashguard and Dogfang mentioned above.
    All works ok and has been ridden a few times in the woods with no chain drop.
    tang
    How about a Lindarets road link, no need to worry about front ring so much as it opens up the possibility of bigger cassette on a short road mech. I’ve just fitted one and it works. I found that Blackspire do a 36t n/w in 110bcd.
The topic ‘Cheapest and Easiest Way Upgrade to 1×10 Cyclocross’ is closed to new replies.
