What's the name/website of that company that makes or sells cheap carbon forks (around £80 if I recall)?
What the difference between some of these cheap forks and say some Pace or on-one carbon forks?
Ta
jon
Ta
jon
Exotic or Carbon CC
The difference? More cash in your pocket, less nice logos/brands
Exotic. That's the one. Ta very much.
I like the idea of more cash in my pocket.
There's Massi (sp) too on ebay, alloy 600gm forks for £40 odds.
Exotic £80ish
Same fork @ £180ish with nice (debateable..) White Bros/Nukeproof branding
back i raise your 80 quid to 110 and give you
took about a week to arrive
actually make the bars and wheel seem connected
ragged them silly at kirroughtree at the 10 under at the weekend and they are solid
look on ebay for a chap called ian ! weighed 530g with an uncut steerer on my scales !
Will have a look at Massi too.
Found that Hylix fork - looks nice but other than that, what does it offer over the Exotic?
the carbon ones are branded hylix, I am thinking of a pair.
EDIT Clubber - the small matter of being 350gm lighter?
I've noticed that some carbon forks are rated as 26"/42cm and some 26"/44cm. Is the 44cm to give a higher front end similar to riding with a suspension fork? Those hylix forks are 45cm. What would that be equivalent to, suspension fork wise?
doesnt ride like a pair of bananas strapped between your steerer and handle bars
its steers like your connected to your wheel
thats specifically why ive been riding bent rc31s for 6 months waiting on the ragley ive yet to ride a stiff (and light) set of tubular carbon forks ....
meanwhile they dampen trailbuzz just as well as my pace did !
I can't help thinking those hylix froks look like road forks bolted on to an MTB, good weight though.
guitarman
im using them on a 29er that specifys a 26" fork of 450mm
420mm is too short for MOST bikes out there today - 420 is non suspension corrected geometry fork really
for refereance a simple fox f100 is 470mm a to c - obviously you have a bit of sag in there too ...
my pace were 440mm and i had them in an 80mm corrected frame before i built the 29er - it was steep.
kingtut - its the ninerlook innit .... if only niner didnt just do 490mm forks !
*shock horror*
Yep I see that, on a niner frame (of any other generic slopey carbon frame) they'd look OK on a normal frame they look a little odd, no offence like.
Are they really that much lighter? Furry nuff if so, I guess..
dunno what exotics weigh but my hylix came in at 530 grams with an uncut steerer.
stoner - you had to fill out the correct paperwork in triplicate and post it out 3 weeks in advance to make a corner with the pace - even then it was like you werent going to make it !
kingtut - with bars like that and a brooks saddle .... im beyond caring what others think about it
- it works for me - and for all its apparent short commings its a very fast and comfortable bike - which was my brief when i started building it
Seriously, though, that's silly... Not the world's stiffest fork but they worked just fine.
made my sids look like monster Ts in the stiffness department
im light
but aggressive and ex downhiller(i say ex but after last weekend thinking of doing a couple of races just for the fun factor) - im fine with rigids but i expect them to do what i tell them an to be flexier than my old 08 sids when at speed just leaves me with no confidence
I'm heavy, I've had them too
I just found that you get used to them very quickly. Same in fact for the original noodle sids...
Fair point, well made.
Cycling components, if clubber can't bend it or break it no one can.
It's true, that...
Clubber - exotic list theirs at 900gm odd IIRC.
I borrowed some early SIDs...rode over a pothole (at medium speed) I wouldn't think twice about on proper forks..they dived, flexed, binded and catapulted me over the bars. I really wasn't interested in getting used to them after that.
Hmmm will have to weigh mine tonight - they really don't feel that heavy but it'll be interesting to see.
I always hear about the SIDs but for the 3ish years I had mine I never really found it a problem and finess is definitely not my strongpoint on a bike...
You have a strongpoint?
Thanks for the info trail_rat. I'll try out my steel rigid forks this weekend (first time out on them) and see how I get on. If I'm a fan and decide I want to shed some weight I'll measure them up to see if they're 42/44/45cm and consider some carbon forks.
I'm riding an on one Scandal - I'm guessing it's not any sort of corrected geometry as it's advertised as loving 100mm forks.
Carbon Exotic's with cut steerer (440mm) are 788g for those interested
Ooh! I have those scales in my kitchen
You forgot to wipe the coke residue from those scales.
they are now sadly broken....
The scales not the forks
You must log in to post.
