The main problem with the biketool type stand (merln, etc) is that is is not incredibly stable.
If you clamp via the seattube – as you should – then taking the front wheel off for example can cause it to close to tipping over.
However if you have a couple of sandbags or similar ready for those times where you need to rotate the bike to a funny angle or similar then it is OK.
You can also have the bike low enough so that one of the wheels touches the ground, which makes things more stable.
I had the Minoura RS5000
http://www.amazon.co.uk/Minoura-4001443-RS-5000-repair-stand/dp/B000OYJFR6
which is the same apart from having a better clamp.
I got rid though for a feedback.
That park looks better than the biketool type stands as the legs splay out further.
