Do as you were doing before. I use TF’s lower lube mix as have half a litre of it, although will enquire if I can use the 0w30 that I use in my Pikes.
Its also worth while using the racing brothers seals, reduces the stiction a lot. Service life isnt as long which is the only downside, but a lower leg service is easy.
The charger damper is a massive improvement over the team internals, I’d fitted a pike to my trail bike back in the summer, which was a big improvement over the revelation. The boxxer felt horribly after riding the pike for a bit, would spike, dive and feel odd.
With the charger damper the boxxer rides much higher in its stroke, I’ve dropped from a hard spring back to a medium. There is less arm pump on long runs, more traction and more confidence in the front end of the bike.
