Morning.
Is the only difference between the Scoop and the Spoon the construction process? Or is one more padded/wider/flexier than the other?
I ask as used a spoon for the first time in a about 3-4 years, after several years of being fine with them, and was a little bit sore after use. Not chaffed or anything, more a bit tender near the sit bones.
Will give the spoon a couple more outings to break the spoon, and my arse in, but wondering if the Scoop would be a viable upgrade down the line. If it’s basically the same, then there would be no point, obviously.
