Viewing 9 posts - 1 through 9 (of 9 total)
  • Changing stems
  • mikey74
    Would I notice changing from a 6 deg stem to a 0 deg rise stem?
    takisawa2
    Only if it was 300mm long. 🙂
    Nah.
    foxyrider
    foxyrider
    turn it over and get a 12 degree then put a 5mm collar in then prob will be about the same and then you can compare?
    Edit: duh or even just take a 5mm collar out and would give you the same effect I would think? 😳
    mikey74
    Sorry, should have said: It's for a 70mm stem.
    foxyrider
    you wouldnt really notice it IMHO –
    breatheeasy
    Probably drop you bars by about 7 – 7.5mm (if my maths is correct). Depends if that's what you want – it might feel a bit different but probably not.
    mikey74
    Yeah it's about 7mm (I worked it out in AutoCAD). I have just remembered that I took the spacers out that were below the stem so if I find it too low, I can always put them back in.
    GaryLake
    I'd say maybe… in terms of handling prob not, but…
    On my full susser, if I remove one 10mm spacer from the bottom and put it on top of the stem, I get the most god awful backache after about 2 hours which doesn't materialise with the spacer back in place.
The topic ‘Changing stems’ is closed to new replies.
