As above, if you;re startign to feel that the 32 is flexy then a change up could be a good thing. Not using the travel adjuster doesn’t seem like the most though through reason, why not just continue not using it. If you’re looking at a 160 coil Lyrik then you still have a travel adjuster not to use.
I had Lyriks and they were ace until they started leaking at the floodgate which seems to be (was?) a common problem, I lost a bit of confidence at that point and sold them on. Would be tempted to get another set and disable the Floodgate.
Not quite the same thing but I’ve just fitted 35mm stanchioned Boxxers to my Stinky to repalce some 66s and the difference in stiffness is massive, never thought I’d ever notice a change but I have. Of course this compares a single crown fork with a dual crown but the stiffer the better I say (fnaarr)
