I’ve ended up with a pretty full set of rings and they’re easy to change so I just experiment each time i’m doing a bike. And what I’ve found is, it’s just not as simple as you’d think, different bikes seem to suit different gearing. Like, this one’s quite obvious with hindsight- but fatbikes are great at going slow, rock-crawling etc, but hard work to go fast. So I’ve downgeared it a long way and I just don’t miss the high gears. The full suss is a constant compromise, it wears big sticky tyres and weighs 30lbs and has to do some very hard days racing, but also it can use a high gear because some trails are warpspeed on it. So it’s got a 30T but I could go up or down and find benefit.
(I went to a 36T just before EWS 2014 at tweedlove, on the 26er full suss and I just about died, I was pretty comfortable on 34T but it just turned out that slightly harder pedalling tipped me over the “sustainable” line and suddenly everything was tiring.)
