This can happen on Shimano 10/11 speed chainsets as the rings are a little dished/offset*, It’s especially bad when mixing Shimano/non-Shimano rings, but if you replaced both rings at the same time the spacing (as in between rings horizontal distance) should be the same, althogh there is some minor variation in spider/tab thickness between manufacturers but not much.
Whatever solution you go with, remember to stick a spare quicklink in with your tube+pump from now on 😉
* might be the same with SRAM as well but I’m not that familair with SRAM road gear.
