I hope the great minds of STW can advise me.
I have altered my Deore octalink triple to a double and bash (24/38 SLX chainrings).
When in the 24 front and 11/13/15 out back the chain rubs on the 38 tooth ring. My octal ink bottom bracket is a 68/113. The LBS tells me that everything is fine and the rubbing is normal, and I shouldn’t use those gears anyway.
I would rather not have the chain rubbing if I could help it so am thinking of changing to a 68/118 bottom bracket. As far as I can work out that should correct the chain line and prevent the rubbing.
My LBS has made me feel stupid but my logic tells me I’m right.
What should I do?
