hi, can’t seem to sort out my chain line. Its a 1×10 set up and the chain appears to be sitting too far out at the chain ring : so it’s ‘/’ as opposed to ‘\’
I’ve therefore brought the chain ring in as much as possible, by removing all BB spacers from he drive side then putting about 4mm worth of washers between chain ring and spider. So much so the chain ring teeth are only about 1mm from the chain stay which isn’t ideal. The line is still ‘/’ and is noisy etc.
am is missing something? The only other thing I can think of doing is somehow moving the cassette outwards using a spacer but that would mean removing the top gear ?!
the photo below was taken before I put the washers on the chainring.
FWIW its a supersteel steel hub and an XT cassette – are these known to sit too high?
<img src=”http://i646.photobucket.com/albums/uu184/mancwilson/IMG_20160117_122616.jpg” border=”0″ alt=” photo IMG_20160117_122616.jpg”/>
