TurnerGuy – Member
The previous chain probably was run for too long – it was cheap and stretched quickly so the cassette might not be that old.
Try a new cassette to see if the slip stops.
If it does then buy another two new chains and run these three chains on a rotation basis so each get an even amount of wear.
Once all the chains have stretched a bit (get a park checker), change the cassette back to the other one, and continue using these three chains for a while longer.
When the chains are knackered, replace with another three new chains and repeat the procedure, switching back to the other cassette if you can – if that one slips then get a new cassette, and rotate across all three cassettes if you can.
That way you will get a good usage of the current cassette and might be able to keep it going for a long time.
POSTED 53 MINUTES AGO # REPORT-POST
Why bother with this faff?
