I’m trying to upgrade my road bike. Currently Tiagra groupset with over 2500 miles.
I’ve fitted…
– New Ultegra cassette (10sp)
– New Ultegra rear derailleur (M cage)
– New KMC chain (10sp)
Shifting is reasonably okay but the chain is not running smooth through the jockey wheels in certain gears.
Top Jockey wheel – seems to ‘ping’ and jump with every revolution
Lower Jockey wheel – chain is trying to slide off the cog (out – away from the cassette) when I’m in largest chainring front, 6th-10 largest cog on cassette. It gets worse from 6th to 10th and louder as it goes.
I’m no expert but I’ve fitted new groupsets before, not sure what’s going on here.
The higher limit screw – seems to be lined up ok and the shifting works reasonably well
Lower limit screw – lets me get to top sprocket, doesn’t allow it to go further
B tension screw – This is very loose, when in smallest cog front + largest cog rear the jockey wheel is quite close to the cassette
Any ideas?
