I had some issues with my gears on the road bike yesterday, while climbing in the smaller front chainring the chain kept skipping and wouldn’t stay in gear on the cassette in rings 2-4(ish), but was fine in the largest ring and 5-11. the chain stayed put, but was a bit noisy when in the larger front ring (I suspect the increased chain tension helps). When I put the bike on a stand the gears all work fine so it’s not a simple indexing issue. The chain and cassette aren’t overly worn so what are the possible issues and where should I start (could it be the cable/outer or is it likely to be more sinister/expensive)? Thanks
