I realise this is probably going to need a gassafe person – I just want to know likely cost and whether its likely to be parts he carries before he starts sucking his gums, dismantles the boiler and leaves us with no heating for a week!
I have a Glowworm Swift Flow 100 combi boiler (probably 18 yrs old).
Hot water doesn’t get above luke warm. When hot water runs the boiler seems to “pulse”, by which I mean the flame fires up then drops back repreatedly and indefinitely.
Central Heating seems to work fine.
If you run hot water when the CH has been on for a while you get a minute or two of properly hot water then it goes back to what you would expect.
Soft water area (central scotland). Boiler does NOT get an annual service. The pressure (CH side only?) does need topped up from <1 bar to >2 bar every three or four months – although I’ve never noticed it make a difference.
SO, possible diagnosis, costs and complexity?
