Hi – I have a pair of Fulcrum red metal 5 wheels with splined hubs. I bought a pair of ashima adapters to allow me to put my 6 bolts on.
I slide the main adapter bit on fine which fits to the spline. however, te lockring you are then meant to put between the apdapter and rotor will not fit as seems to be for a different type of hub (looks like the type you would use to lock a cassette in)
then the ring that screws onto the hub which would lock the centerlock rotor in the goes up agaisn the bolt screws so isnt flush agaisnt anything.
appreciate this ddecription is crap!
basically am i missing a trick here or shoul i just tighten the adapter, fit the rotor then tighten the ring that came on the hub agaisnt the bolts??????
ta
confused-A
