The shock arrived last week, it was fitted at the weekend, and I was able to reuse the mounting hardware from the fox rp23. I just pressed out the bushings using some sockets and a bench vice and pressed them back into the CCDB.
Its set up as per cane creek website base settings,except I reduced the high speed compression damping, and I have it set at ~35% sag, which is pretty much where I had the rp23 sagged to.
First impressions? Small bump sensitivity is much improved, I dont get the chatter that I used to get . Thats all I can say for now, not ridden it over anything more demanding than a set of steps. Will report back when I’ve ridden it over a few rocky peak district descents.
As everyone says , there are lots of adjustments, You get full control of all the compression and rebound damping, plus you get some spacers to tweak the volume of the air chamber to make the spring ramp up more if you need it (I dont think I need these). I can see how it would be very easy to get lost in all the adjustments.
