Viewing 2 posts - 1 through 2 (of 2 total)
  • cb eggbeater bearing size?
  • gavtheoldskater
    anyone know if the end bearing for eggbeaters is a standard size?
    ojom
    If you need them then you WILL need a bush, lock nut and seals.
    Its rarely just the bearing.. if it has gone then it will be due to axial play caused by the worn bush.
    Anywaaaayyyyy, the best option is to buy a rebuild kit.
The topic ‘cb eggbeater bearing size?’ is closed to new replies.
