Shipped my bike over to Australia, got it built up OK. I didn’t bring the old chain as figured it was due a change, they are cheap enough and I couldn’t be bothered/didn’t have the time to start cleaning it when I was having a mad dash to pack everthing.
Ordered a new chain from Merlin, fitted it and gave it a test yesterday, some gear/chain slip. I checked my gear adjustment last night on my bike, seems spot on.
Test ride this morning, chain seems to slip when pedalling but doesn’t do when not under load. It doesn’t seem to jump gears, just slip.
New chain (Sram PC951 9 speed), old casette, approx 500 miles use on it, some trail centres and some fairly soft local riding.
Worn casette could cause this, but it looks OK to me, have seen much worse!? It was fine with the old/worn chain.
Rock and a hard place time then, how long would it take to stretch in do you think?
Well I’ve seen a badly slipping chain ‘wear in’ within a 50m ride, but it could take longer. personally I’d for a new cassette, and cross my fingers the chain rings are good enough to avoid chainsuck.
This is quite normal. Once the chain and a cassette are worn beyond a certain point, a new chain won’t work on the cassette, even though the old ones will happily carry on working together.
I’ve done the change chain @ 0.75% thing,the run 2 chain alternately thing and the run it in to the ground thing. It all ends up about the same cost/time ratio (unless you’re running xtr/xx cassettes in which case change chains every 15 minutes!!!).
By the way, regarding the comments about the smaller cogs on the cassette looking worn, which always pops up on threads like this, take a look at your new one. They are like that by design so its very difficult to judge wear. Front rings are different, if they have that wave profile they are worn. I just run my chain into the ground and replace both chain and cassette at the same time. If it still slips then whichever front ring is guilty gets changed but that’s less frequent.
Running the chain and cassette untill you get slipping is fine for cheaper cassettes. Not for that XTR ot Ti Campag super record cassette they are too expensive
Posted 11 years ago
Viewing 30 posts - 1 through 30 (of 30 total)
The topic ‘Cause of chain slip?’ is closed to new replies.
