Looking for some advice for my roadie. I replaced my original rims with some factory Mavic's a couple of months ago. I swapped the cassette over as this was fine and all seemed OK, needed to adjust the indexing as this was a bit out but all fine after that. I then noticed this week that there is lateral play in the cassette (a few mm of movement along the hub). I have checked the lock ring and this is still tight and the gears are still indexing OK when riding but I'm guessing that there should not be this movement?
I'm 100% sure that I got all the spacers in and in the right order when I swapped the cassette over so what do you think I should be checking for?
