Hi,
Apologies if stem and handlebar size questions come up alot, however I’m making a few adjustments to my Carrera Fury and looking for some advice.
I’ve had the bike for a while and as I’ve progressed and started to ride faster and more technical trails I feel I’m being held back by the handling of the bike feeling twitchy which doesn’t fill me with confidence and the result is me holding on for grim death.
As I can’t (easily) change the head angle I decided to try out some longer bars so I fitted some 750mm bars instead of the 680mm that were on there. This is quite a big jump but I wanted there to be a definite difference to decide if it was good or bad. This feels much better however now when I’m in my normal cycling position my arms are stretched out which isn’t very comfortable. So my question is if I get a shorter stem to bring the bars a bit closer (current stem is 80mm) will this undo the positive difference that the wider bars have made?
Thanks
