Do you know that or are you just assuming so.
Rock Shox (among others) say you must have at least 5mm of spacers above the stem on a carbon steerer to ensure it’s clamped properly.
The headset tensioning thingummies weigh a lot more than a SFN, the old RS one was about 50g IIRC, which is a good chunk of any potential weight saving out the window! In the case of the SID WC XX it also only comes with the Xloc hydraulic lockout, which adds more weight over a crown mounted lockout, so actually the fork ends up being virtually the same weight, if not slightly heavier than one with an alu CSU. Dunno if the Rev is the same.
I’ve had SID WCs, Reba WCs and Spesh AFR forks with a carbon CSU, and never had any problems.
