@russyh it’s funny how some SS wheels are easy to go tubeless and others aren’t. Both my Carbon AM rims had immaculate finishing on every spoke hole but had horrible finishing on the most important hole… the valve. The hole wasn’t round and so the tubeless vale rubber seal couldn’t cover it. I had to pack extra layers of tape over the vale hole to get them to go up in a trial and error fashion. I don’t put sealant in until I can get a proper air seal with my track pump and then it goes in through the removable valve core to keep the beads seated.
I’ve setup tubeless countless times and never had anywhere near the problems I did with the SS carbon rims.
On my Stans rims I can setup Tubeless from scratch in a few minutes and it’s never failed to install first time on two sets of Flows and the one Crest front wheel I accidentally bought on eBay and haven’t ever used but I did set it up tubeless (no sealant) in case I needed it.
I used Hans Dampf SS TrailStar on the front and a Maxxis DHR II TR EXO on the Rear… both tyres I’ve installed on a Flow EX rim in minutes tubeless. You don’t even have to be careful and it works.
I had to be super patient and super careful with the Carbon AMs. Most reasonable people would have given up.
I’ve not had any issues with them since the install but I’m not looking forward to needing a tyre change on them hence keeping the Flows as drop in replacements.
